Stella
I personally would return that new battery if it has already discharged once. Discharging a battery takes away life from the battery. After a full charge it should be load tested to see if it still holds power.
You can charge a battery and it show 12 volts but when a load is put on it the voltage will drop dramatically causing nothing to work.
You should hear a buzz noise when you sit in the seat,then you should hear a click noise behind the dash when you depress the brake to start car. That's normal.
CC knows a lot more and I'm sure he will help soon but I remember the shift module gave some problems with starting. It sounds to me like your fob isn't getting recognized? Which I would think would cause some of the problems your experiencing
Good luck let us know the outcome.
