Important! XLR-V headlight bulbs
toothclark
AL, Millbrook
2006 Black Raven XLR-V
What would be the correct numbers for conversion of all headlight bulbs to LED need the numbers for all bulbs in headlight
Here you go:
Location Qty OEM Bulb LED Replacement Info
Rear view Mirror 2 194
Under Dash 2 194
Glove Box 1 194
Door Courtesy Lights 2 194
Front Side Marker 2 194
Back-up/Reverse 2 3156
License Plate 2 2825LL
DRL 2 3757
Front Parking 2 3157
Front Turn Signal 2 3757
Trunk 1 PC168 Any WLED series or 194 style
Hood 1 Rigid Loop Festoon 44 x 10.5mm - See more at: LED lamp upgrades for passenger cabin. - - Cadillac XLR Forum - Cadillac XLR and Cadillac XLR-V
I have also have been looking for a LED headlight conversion kit, so far I have yet to find one that's a "plug and play" for our D1S bulbs.
DRL’s, front parking light and front turn signal are all the same bulb. If you install LED’s you have to install a resistor or you will get hyper flashing. The BCM thinks your bulb is burned out (or shorted) because the resistance of the LED’s are a fraction of original incandescent bulbs.
I am going to be converting everything in my 2009 to LED before spring. I will post what LED/brand and where I bought them with prices and any installation notes after I complete that project.
