Rocker777
Hey Guys, I'm not sure how many of you have a hard time with your top coming down...but here's some tricks that I figured out on my way to almost losing my mind with a top stuck in the half way position.
1. This is a "factory" thing. Put "both" windows down, and hold for 10 seconds...this resets your electronics.
2. Rock the convertible top up/down switch back and forth until the top comes down.
3. In the trunk "front/left" there's a little well where the hydraulics are. Loose the silver lever releasing the pressure to the hydraulics. Then, on the right of the top, and on the left side. There's a kind of rocker that you can release. It's the part that moves the top flap, Release one side , or both sides. Then re-tighten the silver hydraulics lever in the trunk...that has saved me a million times from loosing my mind with a stuck top!
Good Luck!
Good Luck!
