[solved] Mystery rubber piece found in trunk
luxuryrules
USA
2006 XLR-V
Interesting find this weekend when I was replacing trunk lift supports. Found a loose piece of rubber edge/seal, but can’t determine where it came from. It’s 35 inches end to end, which is not a distance on any of the hard edges on my roof panels, at least not at my first poke around.
Ideas where this is supposed to belong?
Turns out this is the seal attached to the top closeout panel in the center, PN for the whole panel is 19152581 or 88956623 or 88956724, I was able to reattach mine.
My car spent time in Arizona, so I assume the adhesives got a little baked, one end started to peel off and it just eventually worked its way loose over time. It stuck as is, but I’ll need to keep an eye on it, maybe use some adhesive if it comes off again.
