tonypro99
Hello all so my XLR was leaking in the trunk so I decided to do some investigating one night to find out where it was coming from since the carpet in the back was SOAKING WET! So I took out the CD compartment storage in the middle between the drivers and passenger seat and stuck my head inside with a bright LED flashlight while a friend poured water along the trunk. I then could see that water was leaking in from where the trunk sits on the seam of the rear window. So I removed that weatherstripping (Which you must raise the roof down half way down and remove two 5mm bolts that hold the weatherstripping in place) and found that all the adhesive was completely deteriorated. I removed all the old adhesive inside the weatherstripping and along the rear windows edge with some hot water and once everything was clean, I then proceeded to apply adhesive along the flat side edge and in the upper groove as well. We put the weatherstripping back on and used a rubber mallet to tap it into place and tighten the bolts back up and let it dry over night.
The next day it did rain and VOLIA! NO WATER INSIDE THE TRUNK
Now it might seem like a hard project to do but really it only takes about 60 mins and ensures that your trunk is completely dry.
My next project is going to be to design a lid for the rear storage computers angled a few degrees towards the side with a small drain hose so NO water can ever enter into there. I believe this is possible since the computers and pump sit a few inches below. I will take measurements and cut it out of plexiglass and add weatherstripping along the edges of it to ensure a tight seal. I will post pictures and more info when I finish the project!
