Installed new Bilsteins
mickeytee
North Atlanta
In response on some posters on the subject of shocks. I elected to have Bilstein B8 24-020773 and 24-029780 shocks installed on my 2008 XLr.
I hade one of my techs do an alignment check before we started and note the ride height.. this was done on an Hunter alignment rack that is perfectly level. The car was found to be in perfect alignment with front toe only slightly pushing the outer "within specs limit" . 60,000 miles on it. I had installed lower rocker diffusers and the car was scraping them so I planed on raising it about 1/4 inch. The new shocks were installed. the car was driven around to settle and the alignment checked. The car was exactly were it was before the shock replacement. THE CAR WAS NOT HIGHER OR LOWER. MY tech said he had never heard a claim that mono shocks would lower or raise a car.
I felt this was going to be the case as I had spoke with John Trexler head of Tech support at Bilstein about the shocks before buying. He assured me the mono shock would not raise or lower the car. Unlike struts that may. He explained the difference in the B6 and B8 and they are the same shock. The only thing different is the internal valving that controls the ride. He said they could not recommend the B8 or B6 as it was not a direct bolt on due to the mag shock simulators being needed. He also said they had done several xlr cars and the b8 was the shock to use to restore a factory ride to the car. The B6 would be fine if you wanted a softer than stock but still controlled ride.
In driving the car I had forgot over the years how well it used to respond and ride. The mag shocks were shot on the front and he rear were pretty well worn. My tech says instead of looking at the oil on the lower shock to look and see if you have any metallic looking gray or silver grease on the upper portion of the shock housing, under the rubber boot. If you do they have failed. MY car drove just like when I first got it. excellent ride, Unbelievable improvement over the worn out mag shocks.
I had my tech raise the car 3/16 inch on the front and 1/8th on the rear which puts the alignment dead on perfect for the toe end. Toe-in being out can be felt when the front of the car seems to wander. Your car should stay pretty well straight with minimum pressure on the wheel and should return to the "neutral" position on its own after changing lanes. Caster alignment will control how fast it returns but toe will keep it there. Of course roads have a crown in the middle. more in Florida and up north than in the south so you still have to keep your hands on the wheel.
I would highly recommend this change to anyone with worn or damaged mag shocks. I have a set of new mag shocks and this winter I may do some side by side comparisons when I am in Florida to post a video to compare.
The experts at Bilstein were very helpful at putting any question of the shocks changing the ride height to rest. THEY DO NOT CHANGE IT AT ALL. I will say the car when lowered off the overhead rack appeared higher until it was driven around the parking lot and it settled to its original position. The tech said for anyone doing this themselves, be sure all suspension bolts are tightened with full body weight on the car. If you tighten one with the suspension at droop you put pressure on the rubber bushings and it may damage them.
Hey Mickey. I was searching for the Bilstein shocks you mentioned above. I do not find this one: B8 24-020773. What I do find are Bilstein® 24-029773 - B8, so maybe that is just a typo.
Are these the shocks for the like year model Corvettes? Is this the frugal alternative to the magna ride shocks that come on the XLR? My front shocks are leaking though not bad yet, according to Firestone in my pre-purchase inspection. They could not find replacement shocks in their system to give me a repair quote.
Additionally, are there any trade offs in performance, now that you have had a few months to drive it?
If you only have two bad I would replace them with the new mag shocks. your 06 does not suffer the failure of the 04/-05 control module that people wait stupid money for. I have never tried B8 on just the front or rear with factory mag on the other axle. I think the mag shocks at rock auto are about 700 for a pair. you will pay about 300 for a pair of bilsteins plus 200 for the simulators If you re going to do all four then I might consider it. you may be correct on the part number I will double check
You are correct on the part number > I put a 0 for the 9 24- 029773 is the number for the front
Hi all, I just got the Bilstein shocks done on my 07 xlr. Along with new brakes , rotors, and tires. Stock 18 inch wheels with CONTINENTAL EXTREMECONTACT DWS 06 PLUS, 235 50 18. I know this isn't going to be an exact measurement, but I feel like my ride height is off. Can anyone check their rim to fender measurements like in the pics I've loaded?
Mine are as follows
F driver 4 5/8
F pass. 4 7/8
R driver 5 7/8
R pass. 5 4/8
I did have new ride height adjustment bolts/pads installed a few years ago, so maybe only 10k since they were done, I think they should still be good. But maybe just need adjusting. I know I don't want to drop the ride too much because roads in PA suck and I don't like scraping anywhere. But I think they should all be closer to even. Perhaps slightly higher on the drivers side when the car is empty to compensate for when I get in it? Thx for a little feedback on your fender measurements.
Oh and do you think an alignment shop would adjust the ride height as part of an alignment? Should I get an alignment after doing the shocks? Especially if I get the height adjusted? Or do adjustments to the ride height bolts really not effect the alignment...
Ride height can change the camber a very small amount.the shocks wont change the alignment unless you mixed up the washers on the uupper control arms if you pulled them off. The shocks being new may hold your car higher a 1/16 -1/8 inch but drive it and they will settle. Theone concern would be if you had the suspension off the ground on the rear and you tightened the lower bolt. That one needs to be tightnen with the car on the ground or the weight of the rear on jackstands out near the rotors. It can hold the rear higher. The photos look close. Ill look for the factory specs and send them to you
I like those wheels. to me the spacing is equal on both the fenders looks good.
Yes gonna drive it a month and recheck. Was done at a Corvette custom restoration, specialist shop. County Corvette , in West Chester PA . They don't mind working on the XLR. They are more picky than I am. Lol. I didn't measure this before. Just checking it now. I gotta detail the wheels after I break in the new pads. Summer is here😎
