IAN
Flat tires
Mick.
I am not sure that most peoples install the plug from the inside tire as most of time the exterior plug installation is quicker,
If you ever get a flat tire in an unconfortable situation the first solution is by the exterior.
That has been done for so many years, tires comp. they have to make recommendations, doest the installation better from the inside, perhaps, for the side walls as per your picture.
For the horisontal portion of the tire on the surface of the road, the dilamination would be very low of the tire.
My opinion is, its OK for the flat surface of the tire outside / inside installation of the plugs.
When is the last time you had a flat, for me I can not rememder, the low line or the best tires must be build to prevent a such situation, for the safety of the people.
IAN
Mick.
IAN
