- Thread starter
- #21
Test continued: Front wheel on the rear.
The 275/35/19 is on the left and the 235/50/18 is on the right. I mounted the 275 front wheel on the rear for a reference point. I will then use this info for the rears.
As you can see that my hand could clearly reach in between the wheel liner and the wheel.
The front wheels (mounted on the rear) are flush with the body. HRE will remove 2/16" from the original 20" wheel's center piece thus allowing the wheel to move inward. On the previous page the 20x11 was outside the body by 2/16". The goal is to use the outer 2" lip, remove 2/16" from the center piece, and a new inner. The inner will 1/2" or 1" less than the original.
