Fuel tanks
Z1.
If I recall I was mentionng ''fuel tanks '', on how you did it for the EGR hose and it would be great to make a thread for the members.
You mentionned to a member it could be possible to reach the fuel pump with an opening in the rear trunk tub made of fiberglass, I found it could be interesting to tell us how you did in replacing an EGR hose, from the tank #2, in order perhaps for been able to do it for a the fuel pump,
It is obviously impossible to remove the tank from a such small opening, as underneed of the fiberglass tub, are metal components.from the metal body of the car interior..
Correct the c6 is an improved frame, from the c5, and both are of the same design.
Correct it is possible to remove the tank without removing the rear end, I have seen somes video were c6 owners did it.
Thanks to bring up your concern.
IAN
