RubyRod
So this morning I was diddling under the hood while waiting for my laptop to boot so I could connect my old OBD II tools to the car. Anyway ... I removed the cap over the schrader valve on the fuel rail and some fuel shot out. The car wasn't running. I've never seen this before. I had hooked up my mechanical fuel pressure gauge to the rail last weekend to test the fuel pump. Everything checked out A-OK at that time.
Then I started the car. Lo & behold fuel started shooting out of the shrader valve. The cap was still off. I wanted to see if the valve was leaking. It was WAY more than leaking. I shut the engine down before it caught on fire and tightened the schrader valve. It was a little loose. Not much, but a little. I started the car again and fuel continued to shoot out of the schrader valve.
At that point I removed the core and replaced it with a new core for a car/bike tire. I started the car again and no more fuel shooting out of the valve. But ... I'm not sure if the core for a car/bike tire is the correct core. It seemed to fit and for now has solved the leak problem but the seal around the core of the replacement is rubber. I think the one that leaked is Teflon. Has anyone had to replace this core? Do I need to shop for a gasoline tolerant schrader valve core to replace it?
