hawkeye372
I do love those Wind Restrictors and had one for many years. I tend to drive often after dark and when the top is up due to temps. Top up - combined with the wind restrictor there are a ton of double reflections between the Restrictor and the back window. When I had the car down here in Florida two years ago; and being the fact that it is winter so the sun sets early - I often found myself out after dark, and it was cool out so I would be in that situation: top up at night. I took mine off then and never put it back on. I sold it to another XLR-net member from Canada. I don't know if you noticed, but I had the factory mesh one on my car in Bowling Green. It came with my car but was damaged a bit and the straps had pulled out from its rivets so I fixed it (after owning it for nearly 8 years, still had some damage on the one piece) and installed it for BG. I never pointed it out to anyone and not sure if 'anyone' even notice I had the rare factory unit. (Speak up 15 anniversary folks if you did!) I have since removed it as the mesh and its top edge trim is annoying when I look in the rear view: the Wind Restrictor is far less obstructive this way.
Anyway; unless you do a fair bit of night driving with the top up - I am sure you will love it and if you ever go to any cruise nights after dark: they are so cool and can run off a 9 v battery too! It is a fairly easy install, the instructions are great with step by step instructions but yes: you will need someone for that Guy. If I remember correctly it only took about an hour or two to install: the WR company should give you an idea about that and you can tell your installer about the expected time if they dont have experience with them. You can likely purchase one through a local company that specializes in aftermarket installations like led accent lighting, stereos, tinting etc. Good luck with your quest!![]()
Thanks greytoad. No I didn’t notice I guess I only asked you the difference between 09 and the others. Now I wish I had one like yours. But I’m glad I just have a xlr. And thanks for your feed back
