best coolant to add?
"Use a 50/50 mixture of DEX-COOL antifreeze and clean drinkable water."
14.8 quarts / 14 liters as per attached PDF file.
HTH!
Gord
Pretty good read here regarding the color significance:
Well, the coolant level certainly has to be adequate, after that, best look around for leaks. I've had coolant tank levels drop for no reason (in my opinion) so I guess with time they -can- evaporate or maybe get released from the system via overpressure when running (typical radiator overflow hose on to the ground somewhere / sometime you don't notice).
I'd top up the tank to the proper level, go for a drive and watch the temp gauge and of course, for any warning lamps.
HTH & you're welcome!
Gord
"Use Distilled Water !!!!!!!!! Avoid minerals etc., present in drinkable water, entering the system at any level."
I agree with Bill .... distilled water!
