You will be lucky if you can find any . some have been looking for years. You csn swap them all over to a better bilstein.or corvette z06 upgrade or i have another solution if you want to pm me.
RockAuto ships auto parts and body parts from over 300 manufacturers to customers' doors worldwide, all at warehouse prices. Easy to use parts catalog.
www.rockauto.com
A fellow might think there's just a dampening curve or rate change or such, possibly not too noticeable unless really pushed perhaps...or is there something else?
You most likely would not tell any difference between your worn out 06 shocks vs installing new 04 shocks except your wallet would be 2000$ lighter. Shocks were vastly improved in 06 again in 08. always use the lastest part on an older car but never an old part number on a newer car. The 08/09 base and v shared the same shocks and there are a few of those left. Several people have installed them on the 06/07 but fail to come back and give an update as requestef.
A couple of numbers cross Over and show to work on bith but the numbers i have seen Available would give the car a very soft ride dhe to the rearson the xlr being set up for several hu dred pounds more weight. If i ever see andvvegte good used ones for sale cheap, i would give them a try. Im waiting on mine to break a leaf spring so i can swapbto coil overs and see how they work on the car.
