Hello everyone, glad this site is around to support these cars!
I've always wanted one of these cars ever since I saw them at the GM Tech Center being used to put the assembly lines together in 2002, I knew them as the Evoq then. I just finally decided to get one now that the prices have come down, and I found one which needs some work. I just like working on vehicles I guess.
I picked the car up about 100 miles away, I had to drive it home with the top down because the top wouldn't go up, and just about every dash light and gauge was going crazy the entire drive home. The top turned out to be a easy fix, just a arm on a sensor on the toneau popped off, just had to pop it back on! Plus cleaned all the grounds and put in a new battery, no lights at all, and everything works great! To my surprise, no major electrical issues!
Now currently working on replacing the lower radiator support which is broke off on the driver side, replacing the tranny and rearend fluid, and fixing the exhaust to flow better. Then hopefully will enjoy the car for the rest of the summer and fall, before putting it away to fix some paint issues over the winter.
I'm very concerned about all the light issues, my driver side headlight looks like it's been replaced, but it doesn't have a bright light. The passenger headlight has the burnt issue, and yellowed cover, so eventually would like to replace this light, but for the cost they are going for will probably live with that until other options come along, which from the looks of it that may be never. Just purchased a new third brake light, since they are still available. The two tail lights just have a few lights out, but workable.
Anyway, I will be doing a lot of searching on here, thanks for all the great information!
