2004 antenna
josua
Gibsonia, Pa
Long shot. Does anybody have the schematic for the stock antenna setup? It would be the one stuck to the trunk lid. I need a 12 volt source for a rear view camera. Assuming the antenna module has a "switched" 12 volt source.
How about the backup lights. 12volts and come on when in reverse. Wire is close by to where you will be mounting camera.
Going to use that to trigger the cam. I need a feed thats hot when you "turn the key on" like in run
Schematics for antenna:
Thank you sir. That's what i'm looking for
