mickeytee
If you care anything about the value of your XLR please read this. A mechanic on you tube known as the "wizard" is doing a series on the XLR. He sort of praises the car. He bought a basiclly junk one and is going to repair it. Well i watched because i wanted to see how he handled the shocks leaking and the top not working. Instead he decided to fix the head bolt/gasket issue. Problem is that is not an issue.A few people have reported problems but most can be traced to broken radiators or failed cooling fans that cause the car to over heat. Any aluminum head car that over heats will have issues. He makes it sound like ALL XLR have head bolt issues. he is sponsored by a company that sells, you guessed it studs to replace the headbolts. They are a great product and i used them back when the northstar had issues in the 90's. He also talks about the main bearing bolts breaking. They do not unless you are removing them . why would you remove them except you have a failed motor. They dont break under normal conditions. I can give you a list if cars that bolts break when you dont remove them PROPERLY .He mentioned j and j auto parts has 30 something used engines. Its because no one needs them. To someone looking to buy a first time XLR and sees this video , they are going to think along with the problems the car does have they will be needing to spend thousands to replace a motor thats going to fail. If you care, go to the video, post comments about your car so that people reading wont think these cars engines are prone to fail. Oh and the top repair i wanted to see, well its being put off because i suspect he does not know how. to repair it. I like this guy and love Hoovie who made the wizard who he is but he is bringing down our car values by misrepresenting issues for the sake of his channel
