monepit
If you have an 04 or 05 i've learned how to access the nav while driving. In the route screen hold your finger on the bottom right corner of the screen for 10 seconds. There is a hidden botton there. A screen will pop up with about 10 buttons. push the one that says run. NOTE; do not press any other buttons. Once you've done that here comes the tricky part. The return button is under the time bar. You have to slide your finger nail up onto the bottom of the return button. It is easy once you,ve done it a couple of times. once you hit the return button you get the route screen back and you can do anything you want at any speed. This took the XLR nav from totally worthless in my opinion to as good as my garmon. in fact ive took the garmon out of the car now that I can use the nav all the time. I hope this helps some of you because it sure made my day.![Blinzel :blinzel: :blinzel:](/forums/images/smilies/blinzel.gif)
