yikes---- automatic transmission slipping?
SanDiegoXLR
San Diego, CA
2005 Platinum with Shale
Hi all,
When pulling out of my garage in reverse, I come to a complete stop, put it in drive, and now the car is revving a bit before it moves forward.
Today it seemed much worse than it has the last few days- it revved for 2 seconds (like the car was in neutral) and didn't move forward, I put it park, waited a few seconds, back in drive, and it finally moved forward.
Any ideas what is going on?
The car does fine at freeway speeds- no issues in 2nd, 3rd, 4th, and 5th gears. It just has issues coming from reverse....kinda like having a worn out clutch on a manual transmission car.
No codes are showing up in the DIC.
It's at 92k miles with the original automatic transmission fluid- so that definitely needs to be changed soon.
However, this seems like a much more serious problem.
Could it be the Transmission Control Module software?
The torque converter?
The transfer case?
A loose wire or sensor? (like the real wheel sensor for the ABS)
Electronic solenoid?
The main guy at the Corvette shop I go just had open heart surgery....so he can't take a look at it for a while. I'm a bit nervous I'm causing more damage by driving it, so might just take it to the local Cadillac dealership to get a diagnosis (but I don't really trust them after how they have ripped me off in the past).
-Mark
I know this doesn't answer your question/problem, but I'd change the trans fluid and filter(s)
before I'd deal with the dealer. The fluid /filter(s) are 10 years old! Good luck!
Could be shifter cable?
Hi All----good news.....changed the transmission fluid, and that completely fixed the problem!
I know the manual says it's good until 100k, but probably a good idea to change earlier than that- like at 80k.
-Mark
-Mark
hi how is your car driving now? i have exact problem with my 04-93k
did you use what brand of oil dexIII or vI
