MPRCTCL
Couldn't happen on a hotter day and naturally, after sitting at a hot car show for five hours.
The AC is only blowing hot air.
So far, I have observed:
Well, that noise is gone with the heat and now comes on only when the AC compressor is running. The strange thing is, I cannot hear it under the hood. Admittedly, the supercharger is making a little noise, but I cannot tell when it is on or off under the hood but it is very pronounced inside the cabin. I know there really isn't much behind the radio to make noise, so I did a little more investigating. It is actually loudest up at the glass near the center speaker. I haven't tried pulling the fuse for the amplifier to confirm it is not coming out of the speaker, but I don't think it is.
I've attached a video so y'all can hear the mystery noise. I cropped the video down to nothing to keep the file size down and there isn't much to see anyway. I start with the phone by the radio face. then move around to various possible sources ending up back at the center speaker area. Then I turn off the air to make it perfectly clear which sound I was listening for.
Any ideas about the AC? Is the low-side port the one by the firewall? Anyone have a line on a V-compatible compressor when the tech tells me that's the problem? Any other things I can test before I take it in somewhere?
![Melting face :melting_face: 🫠](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1fae0.png)
- Compressor is running when A/C is on.
- No bad under-hood noises
- No DTCs on Tech2
- High-side pressure = 185 psi (per Tech2)
- All doors and actuators seem to be moving properly (per Tech2)
- All the sensors have realistic readings (per Tech2)
- When I put a gauge on the low-side (assuming the low side is closest to the firewall) it pins the gauge at 80psi+ which is way too high, so I'm not adding freon
