Trunk not operational
mtrocket
Billings, Montana
2007 Red Jewel XLR
My friend has an '04. His trunk will operate correctly when putting the top up or down. but not at any other time. The fob button will not operate it (has new battery), the "open trunk" button inside does not operate it. He has to lift it by hand, after getting the fob close the trunk. Then, when open, the "close trunk' button on the trunk lid will not close the trunk' he has to close it by hand. But, the electric pull down will lock the trunk after the trunk is closed. Anyone have any ideas?
Thanks!!
MT,
I had the same issue with mine, and eventually the top would not raise. It turned out that the front position (tonneau) sensor was bad. The readings on the TechII would show the position as ‘mid’. What I believe was happening is that the top cycle would not complete because the front tonneau sensor was not in the ‘closed’ position, so the Top Control Module thinks the top is still in mid cycle. i think the car cannot initiate a trunk open/close if the top cycle is not complete. After replacing the front tonneau top sensor, everything worked fine and the top cycle completed, allowing the truck to open and close. That was a sensor I bought in 2014 and squirreled away.
