ajmarks1
2008 XLR has sat for a while. Took it out for a day trip. Retracted the top, no issues. After returning, went to put the top to the closed position. At step 7 of the close sequence, the top would not raise up from the storage area. I could hear the pump motor running, top would not come up. Reversed the switch, everything went back to the top open position. No messages. tried again, and failed at the same point. Tried to manually lift the top, could raise it a few inches, so the header latch probably released in the process. Dont see any visible fluid leaks that I can tell. Top is now in open position with my cockpit cover on it. Any thoughts? could a weak battery cause this?
