Had a question on the supercharger coolant system. A few months back I took my V into the dealer for a coolant drain and replace since I didn't know when or if this was done by the previous owner. Talked with the (one!) XLR tech, gave him distilled water to use, and asked both before and after about draining and filling the charge cooling system. I even chalk marked the bolt on the filling plate at the top of the charger to make sure they actually opened it up. The chalk mark was rubbed off, but I never checked the level there afterwards. Decided to check this weekend as part of general upkeep, and found it empty up top. I added 22oz of coolant there. This generated a few questions:
1) What is the capacity of the charge cooling system - could not find that anywhere in the service manual - they only seemed to list the entire coolant system?
2) What is the connection between the regular cooling system and the charge cooling system? In reading the threads here it seemed as though there were different opinions on that. I believe the charge cooler has it's own pump, and drain port, and it obviously has it's own fill port - all this suggests they are separate. However, the single capacity listed in the manual, and the gurgling I thought I heard down low in the radiator when I filled the charger's port suggest there may be a connection.
3) If they are connected is it possible that I wasn't really low on coolant up top, and that coolant would be drawn in from the reserve tank into the charge cooling system when the charger/engine heats up?
4) If they are separate, then it would appear the shop drained but didn't fill the charge cooler system, would this generate a code somewhere? If I have been driving gently is there any chance of damage to the charger?
