Recall
There was several recalls across the gm line i believe. Some did not apply to the xlr and a couple only applied to certain cars. There was a recall on some of the fuel systems but its long closed to get anything done. Dont know that one but special coverage usually means if you paid to have something done gm may reimburse you. That number i believe is the drivers seat srs system the plug can drag on the carpet and fray the wire or pull a wire out turning on the srs light. Easy fix if the light does come on.
