It's easy to replace the ignition switch; here's how:
Tools:
1 Six-Pack. At least three chilled glasses.
A good work light.
#2 Phillips screwdriver
6mm socket on at least a 3" extension
1) Disconnect the negative battery cable.
2) Remove the driver Knee Bolster Panel (About knee height under the steering wheel):
a) Pry the fuel door and rear deck lid switches out by of the Knee Bolster panel inserting a plastic trim tool at the bottom edge of each switch to release the locking tabs.
b) Disconnect the electrical connector from each switch.
c) Remove the two lower fasteners using a 6mm socket from the bottom of the Knee Bolster panel.
d) Grasp the panel by the sides and pull rearward to release it from it's locking tabs.
e) Marvel at your handiwork thus far. Hell, have a beer!
3) Remove the Left side Closeout/Insulator Panel (lowest panel on the driver's side):
a) Using the same wondrous plastic trim removal tool, carefully pry out the Instrument Panel (IP) courtesy lamp from the Closeout Panel.
b) Remove the press-on retaining nut from the steering column bracket stud.
c) Release the push-pin retainers to the closeout panel from the IP support beam. The push-pins are captive. Pull the closeout panel straight down, and tip it forward. There's a guide on the front/left. The guide slides into a push-pin.
d) Insert the IP courtesy lamp assembly through the opening in the closeout panel.
e) Set the closeout panel aside.
f) Marvel at your progress. Have another beer.
4) Driver's Ignition Switch Replacement:
a) Remove the retaining screws from the bottom of the DIC switch pad.
b) Pull outwards to disengage the retaining clip.
c) Disconnect the Ignition Switch electrical connector.
d) Remove the Ignition Switch.
e) Looks like it's time for another beer, isn't it?
Reverse the disassembly process. Torque the 6mm Knee Bolster panel fasteners to 16 in-lbs. If you've followed the procedure to the letter, you should have one working ignition switch, and ZERO beers.
Note: This can be used to replace the burnt out light bulbs in the IP too.
CC
