Possible solution for 2004-2005 Radar Cruise Control Module Issues
Johnny Vette
Brentwood California
2005 Crimson Pearl
If anyone has an intermittent issue where the Service Radar Control comes on this might help. I have been having this issue for about 6 months, and was looking for a solution or a used Module which people are asking 800 plus for 14 year old modules that might work. Remove both cables off the battery. Once the cables are removed put a lead between both the Negative and positive cable leads for 24 hours. This will reboot all Computers and Modules. Kind of like resetting a Smart phone. Since I have done this the Cruise control has worked flawlessly. What I think caused the problem in my instance was about 6 moths ago I replaced the brake pads and went to cross drilled and slotted Rotors. I think the module was getting signals from the new brakes that there was an issue so sometimes it would work, but most of the time it would not. The jury is still out and I will be much more confident in the next few months if it keeps working like it has been. Hope this helps anyone with the similar issue.:cool:
cruise control problems
I tried your idea but it didn't help in my case, I hope some others come up with an idea that will work, I like you would hate to spend $800. on something that is not a guarentee.
Servise Cruise Radar
I had that problem. If you look in your owner's manual it tells you how to get to, and clean the radar window. I did, and it then worked perfectly.
radar window
I didn't find anything in my manual about how to get to or clean the radar window, please update me on info.
Thanks; Tom B.
How to clean the cruise radar
Thanks; Tom B.
Page3-29 in the owners Manual tells you how to clean the radar "Window."You pop the black lens on the lower L/side (Driver'side) of the lower grill out carefully with a small slotted screw driver by inserting it in the passenger side when you are facing it. Two tabs hold it in, one at the top, and one at the bottom. Use care, your dealing with plastic! you will see the radar lens behind it. Clean it with a 50/50 mixture of household alchohol and water with a clean soft cloth. re-install the black plastic lens, and your done. It fixed mine, and I hope it fixes yours!
I tried this but didn't help, been out of town so I wasen't able to try your idea right away, don't know what to do next. any one else have any ideas?
