Front turn signal bulb question
shoalsgary
florence, al
05 black
The yellow dual filament lamp behind the lens that crumbles with age should have two functions because it has two filaments. The bright filament is a turn signal, but I can't figure out what the other filament is for. DRL's? The only time that bulb lights on my 05 is for turn signals. Anyone know? I need to know now because I'm refurbishing my headlamps.
Yes, the bulb you mention is both a DRL, always on unless headlights are on, and turn signal. Lots of information on here. Do a search on DRL's
I searched but can’t find how the drl’s Are wired. Mine have no voltage to the DRL filament.
Here is a paragraph from a post on converting the DRLs to LED bulbs.
I HIGHLY recommend reviewing the wiring diagram for the DRLs just to be sure what your wiring should be. For my 2004, the Driver side DRL was the Dark-Blue/white wire and the ground wire that the resistor is tied to. The pass. Side is Lt. blue/white wire and the ground wire. The web site states that the resistor should not be directly mounted on plastic because of heat dissipation. Well, about 90% of our cars are composite/plastic, so I decided to mount these on standoff nuts like those used on PC boards - Radio Shack
Here is the entire post
https://www.xlr-net.com/forums/cadi...ed-turn-signals-drls-post68494.html#post68494
Tim
