Front Stabilizer Bar Bracket Torque Specs
dug-mac
Massachusetts
Hello all,
Does anyone know the torque specs for the above? Mine is the base model. I've tightened the links to 56 ft lbs but don't know the proper setting for these 4 bolts that hold the front sway bar in place. Thanks for your help.
Doug
Thanks for that. Would you happen to know that specs for the nuts that secure the retaining bracket for the front spring? They are the same size as the stabilizer bracket nuts.
Doug
Yes I got the one that said 43 ft lbs. Was there another?
Yes, I answered from my email account so apparently that doesn't work!
"If you are talking about the transverse spring retainer bolts, the spec I have is 46#'s"
Sorry you didn't receive it..
Thanks for your help with this. I torqued all these nuts to 45 ft lbs so I guess that's okay. Would you happen to have the torque specs for other suspension parts by chance?
