Fromwhat im resding you sound like you are dying to remove the headgaket. If your leak is so small you cannot find it with a leakdown where one cylinder is a little higher than the others which is totalky normal on a used motor. You are looking to spend 5-7000$ on a leak repzir. Im sure the head cn be pulked wjthout the engine removed. Ive not done one but at most you might have to drop the front subframe a td. It gas engine bolts removed the head just sitson the block . if you are going with tge dealer body off then you might as well seal the pan, replace the other headgadket, do the timing chsin guides or just drive the car and add a little coolant. If its a headgadket it will get worse in time. With good low mileage engine for 1000$ id never even consider rebuilding one orvtearing into one. Especially an 04 . i also agree if you cnnot find it externally then id check the floor and the heatert. Ive never seen a leak yet that cannot fe fkund with a oressure. Heck. Coolant die in the system With a black light finds a drop a day leaks. Plus a simple cap test on the overflow will show if exhaust gases is getting into the system . ive never seen one of those fail to spot a headgasket leak. Im not sure you stated how large a leak after what period of driving.. 04 had bad radiators. They crack on the upper pasenger side at the overflow tube. The hose can seal the crack except at higher temps and pressure. Also tge radiator tanks leak onthe lower side crimp. You can see them crude up a slight amount but usually on the front side hidden by the ac condensor. With so many engine parts no longer available tearing into it woukd only be an option with me when it dies. Theres no stopping point. Intake can crack when removing. When you have it off o you save labor and put a starter on that may fail? Defiantly the knock sensors and if the cam covers off the vvt actustors and magnetic controllers for sure. Maybe even totally upgrade with heads studs. Id look at the value of the car and be aware that when the trunk leaks and 90% of them do you are looking at another 3-4000$ in module replacement. If you could do it yourself and know 100% its a headgasket, id try. However read about all the engine diwn to repair a smll oil leak that comes back and for some reason they seem to many times need a steering rack when they put it all back together if you have no history of the radiator being replaced that woukd be something that must be done at some point in tbe very near future so id start with that. Id be very concerned with spending tons of money with a shop that cannot find the problem for 100% sure with all the technology we have now. The misfire coukd be a bad injector or coil or plug.all would allow excess carbon to build up. Carbon is soft.makes for a great seal on metal to metal parts. valve to head. Equals higher compresdion. But when hot can ignite cauing a misfire.
Thanks Micky
Your suggestion re re-torquing the head bolts: Is that a generic suggestion or have you known that work on a N* motor?
All excellent advice. I can rule out: plugs, coil packs and injectors. And fuel pump!.
The misfire is for a max of 10 seconds on cold start. Long enough to set the P0308 code. After that, perfect.
The coolant loss is very slight, though definitely there.
I have taken to removing the coolant pressure cap when I park up. This appears to have stopped the (very slight) mis-fire on cold start, reinforcing that the problem is a HG failure.
The coolant cap is fine.
I am considering changing to a waterless coolant, which has a virtually zero vapor pressure.
There is no smell of coolant at all. It is very pungent. Ok, I drive with the roof down, but all the same, there would be some kind of smell. There isn't.
I have checked the "T" piece most carefully, it is perfect.
Re other points: Agree re other HG, yes to timing chains and tensioners, knock sensor too. Radiator was upgraded to a V, same time water pump (and thermostat) was replaced. I am some way from agreeing to this HG job! More I have been discussing with dealership what might be wrong and what is worst case.
I monitor the trunk for leaks.
VMTs
