creaking noise in front suspension
Steve Lee
spring hill
I hear a "little creaking noise" when turning on slightly uneven surfaces at very slow speeds , in parking parking lots, and into my drive way. Would that be caused by the rubber on the ends of the leaf spring under the control arm(s), or are there other causes??
I would say spring adjusters worn out, rocks under them, or broken off completely(unfortunately this is usually what I have experienced)
The above part number shows the "stock spring adjuster bolt stop pad" as being sold in a set of two. Will I need a set of two for each corner or does a set cover both wheels on the axle?
Also can anyone give me the short version on how to replace the bolts?
Thanks,
John B.
Had it checked out on a lift by my mechanic friend, he found nothing. This post was months ago, and now guess what? That creaking has stopped over 2 months ago?? Crazy!!
Thanks,
John B.
Set of 2, one needed for each corner so 2 sets if you want to do both front and rear.
