nwjersey
just got the word from mechanic that my radiator need to be replaced . also cam shaft seal and crank seal leaking . also valve cover gasket is leaking . right height sensor and linkage were snapped . also last but not least all shock seals are leaking . ARE THESE COMMON PROBS ? is it better/cheaper to replace the seals while radiator is out and where can I get oem parts. or should I just go w aftermarket reasonably? thinkin radiator should be oem since car is in mint condition
