MrNorm66
I need help finding the turn signal flasher location 2005
So, when I go to LED bulbs what I do ?There isn't one.
Its controlled by the BCM in software AFAIAK
Thanksyou have to put in load resistors
Do you know if the "ERROR FREE" "Canbus" ones work without a resistor?you have to put in load resistors
OK, awesome. I ordered some earlier this week, they just showed up, I may attempt to install them this weekend (if time permits), otherwise it'll be next weekend. In either case, I'll update as well...I have bought some but haven't installed yet...will let u know.
OK, I installed them, but unfortunately, they work fine just as a turn signal, no hyperflash. But with the DRL's on/active, there's a hyperflash. I wonder if the switch back will resolve this?OK, awesome. I ordered some earlier this week, they just showed up, I may attempt to install them this weekend (if time permits), otherwise it'll be next weekend. In either case, I'll update as well...
