Cadillac Tech
Engine Mechanical - 4.4L | Specifications | Document ID: 1708954
Engine Mechanical Specifications
Application
Specification
Metric
English
General
- Engine Type
- Displacement
267 cu in
- RPO
- VIN
- Bore
3.5827 in
- Stroke
3.3071 in
- Compression Ratio
- Engine Compression Test
131-158 psi
- Firing Order
- Spark Plug Gap
0.0400 in
Lubrication System
- Oil Capacity - with New Dry Oil Filter
8.0 Quarts
- Oil Pressure - Minimum @ Idle
5 psi
- Oil Pressure - Minimum @ 2,000 RPM
35 psi
