Thats a lot of fluid and its got to go somewhere. look and see if its foaming in the reservoir. Ive heard of problems with the reservoir having a baffle inside that breaks and stops up the supply line. Also the hose from the reservoir to the steel line can suck shut and cause air which foams andvleaks out. But f it does its around the lid so should be easily seen. I would wrap a rag around the lid just to see. Also i m not sure if the power steering cooler is in the radiator or seperate. if in the radiator check the coolant to see if it has fluid in it. Andbof course it could be the rack at the fittings or leaking out around the rubber boot on the tie rods
