Date: September 28, 2006
Subject: Intermittent Service Stability Message On DIC With Only DTC C0561 Symptom 71
Models: 2005-2007 Cadillac XLR and XLR-V
2005-2007 Chevrolet Corvette
Intermittent Service Stability Message on the DIC with ONLY DTC C0561 Symptom 71 set in history or current. This is the result of a software concern within the EBCM
Revised EBCM software is under development. Replacement of the EBCM or BCM will not correct this condition. Revised software should be available in November 2006.
Article ID: 70
Online URL: https://www.xlr-net.com/knowledgebase/article/2005-2007-cadillac-xlr-and-xlr-v-service-bulletin-intermittent-service-stability-message-on-dic-with-only-dtc-c0561-symptom-71-70.html
