2006 Cadillac XLR-V: Service Bulletin: Automatic Transmission, Busy Shifting, MIL Illuminated, DTC P1751
Service Bulletin #:  1741321
Date: December 9, 2005
Subject:  Automatic Transmission, Busy Shifting, MIL Illuminated, DTC P1751
Model(s): 2006 Chevrolet Corvette, 2006 Cadillac XLR-V and STS-V, 2007 Cadillac Escalade, 2007 GMC Yukon
Equipped with 6L80 (RPO - MYC) Automatic Transmission
Some customers may experience busy or frequent up and down shifts in 3rd, 4th, 5th or 6th gear at approximately 30-50 mph. The MIL may also be illuminated and a DTC P1751 stored in the TCM.
These conditions may be caused by an undersized hole or debris in the control valve body spacer plate.
To correct this condition the control valve body spacer plate must be replaced. These parts are not currently available from GMSPO and must be obtained by contacting Technical Assistance. If the control valve body spacer plate is required a complete valve body assembly including TCM will be sent to the dealer at no charge.
Service Procedure
Refer to SI document # 1670458 - Control Valve Lower and Upper Body Replacement for the proper procedure. The TCM must be programmed after installation of the control valve body assembly, refer to SI document # 1466621 - Transmission Control Module Programming and Setup. Service Fast Learn Adapts must also be run, refer to SI document # 1688788 for that procedure.
Article ID: 61
Online URL: https://www.xlr-net.com/knowledgebase/article/2006-cadillac-xlr-v-service-bulletin-automatic-transmission-busy-shifting-mil-illuminated-dtc-p1751-61.html
