Below is a listing of specifications for the 6L80 Transmission used in the 2006 - 2009 Cadillac XLR-V:
Application | Ref No. | Quantity | Size | Specification | |
Metric | English | ||||
Case Extension Stud to Case Extension | 17 | 2 | M10x1.5 | 15 Y | 11 lb ft |
Case Extension to Case Assembly | 16 | 6 | M10x1.5x40 | 55 Y | 41 lb ft |
Control Solenoid Valve Assembly and Control Valve Lower Body Assembly to Control Valve Upper Body Assembly | 310 | 6 | M5x0.8x55 | 8 Y | 71 lb in |
Control Solenoid Valve Assembly and Control Valve Lower Body Assembly to Control Valve Upper Body Assembly | 309 | 10 | M5x0.8x45 | 8 Y | 71 lb in |
Control Solenoid Valve Heat Sink to Valve Body | 312 | 2 | M5x0.8x53 | 8 Y | 71 lb in |
Control Valve Upper Body Assembly to Control Valve Lower Body Assembly | 301 | 12 | M5x0.8x36 | 8 Y | 71 lb in |
Control (with Body and Valve) Valve Assembly to Case Assembly | 22 | 6 | M5x0.8x73 | 8 Y | 71 lb in |
Fluid Pan Assembly to Case Assembly | 30 | 18 | M6x1.0x20 | 9 Y | 80 lb in |
Trans Oil Level Check Plug to Fluid Pan Assembly | 31 | 1 | M12x1.75 | 25 Y | 18 lb ft |
Fluid Pump Cover Assembly to Torque Converter Housing | 231 | 13 | M6 1.0x40 | 11 Y | 97 lb in |
Input and Output Speed Sensor Assembly to Control Valve Upper Body Assembly | 302 | 2 | M6x1.0x20 | 12 Y | 106 lb in |
Line Pressure Test Hole Plug to Torque Converter Housing | 202 | 1 | 1/8–27 NPTF | 11 Y | 97 lb in |
Manual Shaft Detent Assembly to Valve Body | 23 | 1 | M6x1.0x14.5 | 12 Y | 106 lb in |
Torque Converter Housing Assembly to Case Assembly | 3 | 9 | M10x1.5x50 | 72 Y | 53 lb ft |
*Reference number refers to the component callout number in Disassembled Views |
Name | 6L80 |
RPO Codes | MYC |
Production Location | Ypsilanti, Michigan (USA) |
Transmission Drive | Rear Wheel Drive |
1st Gear Ratio | 4.027 |
2nd Gear Ratio | 2.364 |
3rd Gear Ratio | 1.532 |
4th Gear Ratio | 1.152 |
5th Gear Ratio | 0.852 |
6th Gear Ratio | 0.667 |
Reverse | 3.064 |
Torque Converter Size– Diameter of Torque Converter Turbine | 258/300 mm |
Pressure Taps | Line Pressure |
Transmission Fluid Type | DEXRON VI® |
Transmission Type: 6 | Six Forward Gears |
Transmission Type: L | Longitude Mount |
Transmission Type: 80 | Product Series |
Position Quadrant | P, R, N, D, S (some models) |
Case Material | Die Cast Aluminum |
Transmission Net Weight– Approximate | 100 kg (220 lb) |
Maximum Trailer Towing Capacity | Refer to applicable owner’s manual |
Application | Specification | |
Pan Removal– Approximate Capacity | 6.2 liters | 6.5 quarts |
Overhaul– Approximate Capacity (STSV/XLRV) | 9.5 liters | 10 quarts |
Overhaul– Approximate Capacity (Corvette) | 11.8 liters | 12.5 quarts |
Complete Trans System Fluid Capacity (STSV) | 10.01 liters | 10.58 quarts |
Complete Trans System Fluid Capacity (XLRV) | 10.32 liters | 10.91 quarts |
Complete Trans System Fluid Capacity (Corvette) | 12.53 liters | 13.24 quarts |
Size Classification | Thickness (mm) | Thickness (in) |
Note:
The fluid pump assembly has selective rotor and slide components. These components are chosen based on pump body dimensions. Fluid pump rotor and slide components are available in three size classifications (1, 2, 3) with the following tolerances: |
Rotor Selection | ||
1 | 17.948–17.961 | 0.7066–0.7071 |
2 | 17.961–17.974 | 0.7071–0.7076 |
3 | 17.974–17.987 | 0.7076–0.7081 |
Slide Selection | ||
3–5 Reverse Clutch
Clutch Pack Travel Specification – 1.21–1.79 mm (0.048–0.070 in) | ||
Retaining Ring Thickness | O.D. Color | |
Note: After measuring clutch pack travel, determine if the measurement is within the specification. If the measurement is not within the specification, measure the thickness of the existing retaining ring, and then choose a thicker or thinner retaining ring that will bring the measurement within specification. |
1.61–1.71 mm | 0.063–0.067 in | Gray |
1.88–1.98 mm | 0.074–0.078 in | Light Green |
2.15–2.25 mm | 0.085–0.089 in | Yellow |
2.42–2.52 mm | 0.095–0.099 in | None |
2.69–2.79 mm | 0.106–0.110 in | Purple |
1–2–3–4 Clutch
Clutch Pack Travel Specification – 1.53–1.99 mm (0.060–0.078 in) | ||
2.96–3.06 mm | 0.117–0.120 in | Light Blue |
3.23–3.33 mm | 0.127–0.131 in | Orange |
3.50–3.60 mm | 0.138–0.142 in | White |
4–5–6 Clutch
Clutch Pack Travel Specification – 1.28–1.89 mm (0.050–0.074 in) | ||
Note: After measuring clutch pack travel, determine if the measurement is within the specification. If the measurement is not within the specification, measure the thickness of the existing retaining ring, and then choose a thicker or thinner retaining ring that will bring the measurement within specification. | ||
1.60–1.70 mm | 0.063–0.067 in | Yellow |
2.02–2.12 mm | 0.080–0.083 in | None |
2.44–2.54 mm | 0.096–0.100 in | Purple |
Low/Reverse Clutch
Clutch Pack Travel Specification – 1.30–2.07 mm (0.051–0.081 in) | ||
1.85–1.95 mm | 0.073–0.077 in | Yellow |
2.26–2.36 mm | 0.089–0.093 in | None |
2.67–2.77 mm | 0.105–0.109 in | Purple |
(1) | Model Year |
(2) | Model Code |
(3) | Transmission Family |
(4) | Transmission Assembly Number |
(5) | Julian date |
(6) | Sequential Serial Number |
(7) | Source Code |
(8) | Broadcast Code |
(9) | Bar Code |
(10) | Transmission I.D |
Article ID: 18
Created: December 18, 2016
Online URL: https://www.xlr-net.com/knowledgebase/article/2006-2009-cadillac-xlr-v-6l80-transmission-specifications-18.html
