Subject: | Flash To Pass Inoperative With Headlamps Off | |
Models: | 2004 - 2009 Cadillac XLR | |
2006 - 2009 Cadillac DTS |
This PI was superseded to update model years. Please discard PIC3998A.
The Cadillac XLR and DTS use a single High Intensity Discharge (HID) lamp on each side of the vehicle. These lamps perform both high and low beam headlamp functions through the use of a plate built into the lamp. This plate partially covers the lamp during low beam operation and fully retracts during high beam operation.
When first turned on, HID Headlamps may take a few seconds to reach full intensity. As a result, the flash to pass feature does not operate unless the headlamps are already illuminated.
This is a normal characteristic. No repair attempts should be made.
Article ID: 158
Created: January 10, 2020
Last Updated: January 10, 2020
Online URL: https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pic3998b-flash-to-pass-inoperative-with-headlamps-off-158.html
