2009 Cadillac XLR: Service Bulletin: #PIT4162H: Service Stability Lamp DTC C0131 - (Jun 17, 2011)
Subject Service Stability Lamp DTC C0131
Models 2008-2011 Buick Enclave
2007-2011 Cadillac Escalade, ESV, EXT
2009 Cadillac XLR
2007-2011 Chevrolet Avalanche, Silverado 1500 w/JL4, Suburban 1500, Tahoe, Traverse
2011 Chevrolet Corvette
2007-2011 GMC Acadia, Sierra 1500 w/JL4, Yukon, Yukon Denali, Yukon XL 1500, Yukon Denali XL
2007-2010 Saturn Outlook
This PI was superseded to update model years. Please discard PIT4162G.
Some customers may comment of an ABS lamp illuminated followed by a Service Stability message displayed in the Drivers Information Center. After Initial diagnosis, technicians may find a diagnostic code C0131 set in the EBCM. Removing an EBCM from one vehicle and installing it in another vehicle (for test purposes) will likely cause a DTC C0131 to set for a brake pressure sensor calibration value out of range.
If you experience this DTC after replacing or swapping the EBCM, the DTC can be cleared by performing a brake pressure sensor calibration with the Tech 2 by accessing the following menus: Chassis/ EBCM/ Special Functions/ Brake Pressure Sensor Calibration.
Use the Tech 2 soft keys to "Enable" the calibration. After the soft key is pressed you should see the Command State change from "None" to "Enable". Continue to wait until the command state changes from "Enable" to "Off". Once completed, back out of the Tech 2 and turn off the Ignition Key and Tech 2 and wait 1 minute before cycling the key back on. This will allow the EBCM to complete the learn procedure.
Note: Make sure your Tech 2 is on the latest version. This reset function was not available until version 27.001, released 01/03/07
Article ID: 145
Created: January 9, 2020
Last Updated: January 9, 2020
Online URL: https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4162h-service-stability-lamp-dtc-c0131-jun-17-2011-145.html
