Subject: | HID Headlamps Flutter Vertically Over Bumps | |
Models: | 2008 - 2009 Cadillac XLR & XLR-V |
Some customers may comment when driving in the dark, the head lamp beam flutters vertically when driven on moderate to rough road surfaces. The adaptive forward lighting assembly with in the head lamp assembly allows some motion when the lamp experiences road impacts transmitted through the vehicle suspension and structure.
Inspect the lamp assembly to ensure it is properly fastened to the vehicle sub structure. Visually inspect the HID lamp assembly inside the head lamp assembly. It should be centered in the lamp opening. If no obvious issues are noted the lamp is most likely operating as intended. As with any moving part some deflection can be expected when the assembly experiences road shock inputs. Verify this is a normal condition by comparing to a like vehicle. Once verified, do not replace the headlamp assembly.
Article ID: 139
Created: January 8, 2020
Last Updated: January 8, 2020
Online URL: https://www.xlr-net.com/knowledgebase/article/2008-2009-cadillac-xlr-and-xlr-v-service-bulletin-pic4911-hid-headlamps-flutter-vertically-over-bumps-139.html
