Subject: | SES Light with Fuel Trim and or Oxygen Sensor Codes |
Brand: |
Model: |
Model Year: |
VIN: |
Engine: |
Transmission: | ||
from |
to |
from |
to | ||||
All |
All |
2000 |
2018 |
All |
All |
All |
All |
Supersession Statement
This PI was superseded to update Model Years. Please discard PIP4925
A customer may comment the vehicle has an SES light on. Initial diagnosis may display any of these fuel trim and/or O2 sensor related codes, P0101, P0137, P0138, P0140, P0141,P0157, P0158, P0160, P0161, P0171, P0174, P0420, P0430, P1174, P1175, P2096, P2097, P2098, P2099, P2177, P2178, P2179, P2180, P2187, P2188, P2189, P2190. P2270, P2271, P2272, P2273.
If normal SI diagnostics does not lead to a resolution and an intake vacuum leak or an exhaust leak is suspected, the use of the J41413-200 Evaporative System Tester smoke machine may be useful to find the leak.
For an intake leak the smoke can be introduce into the brake booster hose or the oil dipstick tube.
For best effect covering the air intake before the MAF sensor to allow air pressure to build is recommended.
For an exhaust leak the hose into the tailpipe sealed with shop towels proves to be effective.
This method is very good for finding small leaks around the O2 sensor embossments and slight cracks in an intake plenum or gasket.
This process was also recommended in the 10207.07D - July 2007 Emerging Issues training seminar.
Article ID: 122
Created: March 22, 2017
Last Updated: March 22, 2017
Online URL: https://www.xlr-net.com/knowledgebase/article/2004-2009-cadillac-xlr-service-bulletin-pip4925a-ses-light-with-fuel-trim-and-or-oxygen-sensor-codes-mar-21-2017-122.html
