Subject: | Additional Wheel Speed Sensor Diagnostics |
Models: | 2008 - 2013 Buick Enclave |
2007 - 2013 Cadillac Escalade, Escalade ESV, Escalade EXT 2009 Cadillac XLR | |
2007 - 2013 Chevrolet Avalanche, Silverado, Suburban, Tahoe | |
2008 - 2012 Chevrolet Express | |
2010 - 2013 Chevrolet Camaro | |
2009 - 2013 Chevrolet Corvette, Traverse | |
2007 - 2013 GMC Acadia, Sierra, Yukon, Yukon XL, Yukon Denali, Yukon Denali XL | |
2008 - 2013 GMC Savana | |
2008 - 2009 Pontiac G8 | |
2007 - 2010 Saturn Outlook | |
With any of the following DTCs: C0035 C0040 C0045 C0050 C0245 P0609 |
This PI was superseded to update model and model years. Please discard PIT4683E.
When diagnosing a wheel speed sensor concern it may be found that the 12 volt Wheel Speed Sensor Supply Voltage circuit from the EBCM has no voltage. This may incorrectly lead to the replacement of the EBCM because there is no voltage to the WSS. When the EBCM has a fault with a WSS, it internally turns off the supply voltage to the WSS.
Note: The only part of this PI that applies to the Vans or HD pickups is Step 2 under the Recommendation.
Below are some additional diagnostic tips to help diagnose WSS concerns after the SI ″Circuit Testing″ has been performed:
Note: These tests should only be performed after the SI2000 ″Circuit/System Testing″ is complete; and prior to an EBCM replacement.
Note: This procedure is very polarity sensitive and if the WSS is connected in reverse polarity while performing the below procedure the WSS can be permanently damage. Please make sure the B+ is connected to the WSS Supply Voltage and the ground (Fluke 87 DVOM) to the WSS Low Signal Return. Use the appropriate SI wiring diagrams to determine the WSS Supply Voltage and WSS Low Signal Return.
Article ID: 115
Created: March 14, 2017
Last Updated: March 14, 2017
Online URL: https://www.xlr-net.com/knowledgebase/article/2009-cadillac-xlr-service-bulletin-pit4683f-additional-wheel-speed-sensor-diagnostics-jul-31-2012-115.html
