2009 Cadillac XLR and XLR-V: Service Bulletin: #PIT4617: Express Window Up Feature Inoperative After Using Retractable Roof
#PIT4617: Express Window Up Feature Inop After Using Retractable Roof - keywords down express feature inoperative left right roof up window - (Apr 4, 2008)
Subject Express Window Up Feature Inop After Using Retractable Roof.
Models 2009 Cadillac XLR Platinum and V-Series
Some customers may comment that the express window up feature is inoperative after cycling the retractable roof. The express window up feature is a function of the retractable roof switch. On prior model year XLR’s, after the roof has completely closed, the roof switch can be pressed a second time and both driver and passenger windows will express up to a closed position. This feature was eliminated on 2009 and future model year XLRs due to new Motor Vehicle Safety Standards (MVSS) requirements. This will typically be a concern expressed by customers that owned a prior model year XLR who now own a 2009 model year vehicle.
This is normal operation. DO NOT make any repair attempts for this concern.
