2006 - 2009 Cadillac XLR-V: Service Bulletin: #PIP4493: SES Light due to DTCs P0171 and/or P0174 - Inspect Air Cleaner Outlet Duct and Supercharger Inlet Duct Clamps
#PIP4493: SES Light due to DTCs P0171 and/or P0174 - Inspect Air Cleaner Outlet Duct and Supercharger Inlet Duct Clamps - (Oct 3, 2008)
Subject SES Light due to DTCs P0171 and/or P0174 - Inspect Air Cleaner Outlet Duct and Supercharger Inlet Duct Clamps
Models 2006 - 2009 Cadillac STS-V, XLR-V
with 4.4L Supercharged V8 Engine (RPO LC3)
A SES light may be experienced as a result of DTCs P0171 and/or P0174 stored. This may be the result of unmetered air entering the engine through the air cleaner outlet duct or supercharger inlet duct connections due to a mis-assembled connection or loose clamps.
If the SI diagnostics do not isolate a cause for this concern, carefully inspect the air intake duct from the air cleaner box to the supercharger inlet duct, and the front and rear supercharger inlet ducts for mis-assembled connections and correct them as necessary. Also, perform the suggestions below for the model you are working on, and re-evaluate the concern:
For STS-V:
1) Tighten the air cleaner outlet duct clamps to 3 NM (27 lb-in).
2) Tighten the 526, 852, and 853 supercharger inlet duct clamps to 2.5 NM (20 lb-in).
For XLR-V:
