2005 - 2009 Cadillac XLR: Service Bulletin: #PIC3724B: Power Window(s) Reverses During Express Close
Estimated Reading Time: 1 Minutes#PIC3724B: Power Window(s) Reverses During Express Close - keywords down driver glass intermittent passenger switch up window - (Nov 10, 2008)
Subject: | Power Window(s) Reverses During Express Close | |
Models: | 2005 - 2009 Cadillac XLR |
This PI was superseded to update model years. Please discard PIC3724A.
Power windows may reverse during the express close function. This may be due to the door window contacting the A pillar weather-strip. This contact creates friction which causes the window to reverse as if it was obstructed.
Adjust door glass by slightly tipping the top of the window outward. Adjust in small increments so not to induce a wind noise or water leak. Reinitialize power windows and re-evaluate window operation.
