2004 - 2009 Cadillac XLR: Service Bulletin: #PIC4095B: Options Not Available Message Displayed On The DIC
#PIC4095B: Options Not Available Message Displayed On The DIC - keywords 1st 2nd 3rd 4th fob key personalization - (Sep 15, 2008)
Subject Options Not Available Message Displayed On The DIC
2005 - 2009 Chevrolet Corvette
This PI was superseded to update model years. Please discard PIC4095A.
When entering the vehicle, the "Options Not Available" message may display on the DIC. This is the result of a customer entering the vehicle with a 3rd or 4th key fob programmed to the vehicle. Entering with a 3rd or 4th programmed fob, the driver will be able to change all personalization settings for that ignition cycle. None of the personalization features selected or changed will be able to be recalled to the 3rd or 4th key fob. Only the key fob(s) programmed for Driver 1 and/or 2 can be programmed to recall personalization features.
This is a normal operating characteristic and no repairs are recommended. Entering the vehicle with any other fob not programmed for Driver 1 or Driver 2 will result with this concern.
