2004 - 2009 Cadillac XLR and XLR-V: Service Bulletin: #PIC3225J: Set Up RCDLR After Replacement
#PIC3225J: Set Up RCDLR After Replacement - (Apr 13, 2018)
Subject Set Up RCDLR After Replacement
Brand:
Model:
Model Year:
VIN:
Engine:
Transmission:
from
to
from
to
Cadillac
XLR
2004 - 2009
All
All
All
All
Chevrolet
Corvette
2005 - 2013
All
All
All
All
Supersession Statement
This PI has been superseded to update Model Years. Please discard all copies of PIC3225H.
There have been questions regarding the programming and/or set up when replacing the Remote Control Door Lock Receiver (RCDLR). The following steps can be used as a guide when replacing the RCDLR.  As always, please refer to Service Information (SI) for the replacement instructions.
2004 Cadillac XLR
Important: When replacing ANY components in the RKE system, have the Parts department contact Partech to verify that the correct PN components are being ordered. Originally, the RCDLR and the transmitters were only available as a preprogrammed matched set for the 2004 Cadillac XLR. This is no longer the case. All components are currently available separately.
  1. Plug in the new RCDLR
  2. Perform module setup in the scan tool.
  3. Program the Theft Deterrent System learn using either the 10 or 30 minute theft relearn procedure. (eSI Document ID # 1460252). Canada and Export vehicles will not allow 30 minute autolearn procedure.
  4. Learn the tire pressure sensors. (eSI Document ID # 1396476)
2005 - 2009 Cadillac XLR and 2005 - 2013 Chevrolet Corvette
  1. Verify that the Tech 2 is on version 33.004
  2. Perform the RKE transmitter programming procedure. If the RCDLR has been replaced, select the instructions in SI for "New RCDLR ONLY" (eSI Document ID # 2310804)
  3. Perform the RCDLR Setup procedure using the Tech 2.
  4. Perform the Theft Deterrent System learn using the 10 or 30 minute theft relearn procedure for Domestic, Canadian, or Japanese vehicles.  Other Export vehicles will not allow the 30 minute autolearn procedure.
  5. Perform the TPM sensor learn procedure.
