Intermediate and Overdrive Clutch Housing Retaining Ring Specifications
Dimention M
Retainer Ring Thickness (mm)
Retainer Ring Thickness (in)
0.85 mm –0.95 mm (0.033 in – 0.037 in)
3.80–3.90
0.149–0.153
0.95 mm –1.05 mm (0.037 in – 0.041 in)
3.70–3.80
0.145–0.149
1.05 mm –1.15 mm (0.041 in – 0.045 in)
3.60–3.70
0.141–0.145
1.15 mm –1.25 mm (0.045 in – 0.049 in)
3.50–3.60
0.137–0.141
Transmission Fluid Pump Specifications
Size Classification
Thickness (mm)
Thickness (in)
Important:
Rotor and slide must be chosen from the same size classification as the oil pump body.
Allowable rotor and slide to fluid pump body end play is as follows: Specification
Slide to fluid Pump Body End Play — 0.030–0.051 mm (0.0012–0.0020 in)
Rotor to fluid Pump Body End Play — 0.030–0.051 mm (0.0012–0.0020 in)
The fluid pump assembly has a selective rotor and slide components. These components are chosen based on pump body dimensions. Fluid pump rotor and slide components are available in five size classifications (1, 2, 3, 4, and 5) with the following tolerances:
Rotor Selection
1
17.948–17.961
0.7066–0.7071
2
17.961–17.974
0.7071–0.7076
3
17.974–17.987
0.7076–0.7081
4
17.987–18.000
0.7081–0.7086
5
18.000–18.013
0.7086–0.7091
Slide Selection
1
17.948–17.961
0.7066–0.7071
2
17.991–17.974
0.7071–0.7076
3
17.974–17.987
0.7076–0.7081
4
17.987–18.000
0.7081–0.7086
5
18.000–18.013
0.7086–0.7091
Fluid Pump Body Depth
1
17.978–18.012
0.7077–0.7091
2
17.978–18.025
0.7083–0.7096
3
18.004–18.038
0.7088–0.7101
4
18.017–18.051
0.7093–0.7106
5
18.030–18.064
0.7098–0.7111
Transmission General Specifications
5L40-E/5L50-E
RPO Codes
MV3 AWD, M82, MX5 AWD, M22
Production Location
Strasbourg, France
Vehicle Platform (Engine/Transmission) Usage
D, E, Y
Tranmission Drive
Rear Wheel Drive
1st Gear Ratio
3.42:1
2nd Gear Ratio
2.21:1
3rd Gear Ratio
1.60:1
4th Gear Ratio
1.00:1
5th Gear Ratio
0.75:1
Reverse Ratio
3.03:1
Torque Converter Size (Diameter of Torque Converter Turbine)
