Document ID: 2460616
#PIC4159B: Revised Fuel Sender Values For The Chevrolet Corvette And The Cadillac XLR - keywords PIC4159 PIC4159A - (May 3, 2010)
Subject: Revised Fuel Sender Values For The Chevrolet Corvette and Cadillac XLR
Models: 1997-2007 Chevrolet Corvette
2004-2007 Cadillac XLR
PI is being re-instated.
The information below is designed to assist with fuel level concerns. The information below are all APPROXIMATE values only.
Note: The fuel sensor values have changed beginning with the 2007 model year vehicles. Be sure to use the correct values based on the model year that is being worked on. Essentially the resistance values are inverted from previous model years.
All Values Below Are Approximate Fuel Sensor Values
2007 Corvette and 2007 XLR
Fuel Gage Display Fuel Level Sensor Left - Primary Fuel Level Sensor Right - Secondary Fuel Level - Gallons Fuel Level Remaining Parameter
Resistance - ohms Volts Resistance - ohms Volts
E 167 - 250 2.04 - 2.5 250 2.54 0 - 2 3.8L (1.0 gal)
1/4 77 1.20 250 2.54 5.9 22.3L (5.9 gal)
1/2 40 0.71 250 2.54 9.9 37.5L (9.9 gal)
3/4 40 0.71 164 2.01 14.1 53.4L (14.1 gal)
F 40 0.71 40 - 45 0.71 - 0.78 17 - 18 68.1(18.0 gal)
1997-2006 Corvette and 2004-2006 XLR
E 40 - 57 0.71 - 0.95 40 0.71 1 3.8L (1.0 gal)
1/4 191 2.20 40 0.71 5.9 22.3L (5.9 gal)
1/2 250 2.54 40 0.71 9.9 37.5L (9.9 gal)
3/4 250 2.54 164 2.01 14.1 53.4L (14.1 gal)
F 250 2.54 215 - 250 2.35 - 2.5 18 68.1(18.0 gal)
