Service Bulletin #:  06-02-35-002
Date: January 2006
Subject:  Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC) (Inspect and Secure Wires in SWPS Connector)
Model(s):
2005 - 2006 Chevrolet Corvette
with Steering Wheel -- Tilt, Telescoping (RPO N37)
Attached below is the PDF document for this service bulletin.
06-02-35-002
