2004 - 2005 Cadillac XLR: Service Information: No Crank, PRNDL Inoperative
Estimated Reading Time: 1 MinutesOwners of some 2005 Chevrolet Corvettes and 2004 - 05 Cadillac XLRs may experience a no-crank condition, with no codes in any module. The concern may be followed by an inoperative transmission range indicator (PRNDL). The Tech 2 will show the transmission range circuits are all reading high when any gear is selected.
Check for a loose or broken ground G402 at the right rear suspension cradle. See SI document 1495107.
- Thanks to Paul Radzwilowicz, GM Techlink, July, 2005
